Buggywhips
Hello everyone, new to forum. Great info here and I hope to help people with what I can also.
My issue- I’ve rebuilt the carb, then changed out entire carb, carbon seal, jet pump and impeller and wear ring, checked compression which is 130/150. Replaces lines, adjusted throttle and tried to set high speed low speed. Plugs are dry after running and look to be running very hot.
I put new plugs in - was able to get up on plane and in ran good for about 5 minutes before fouling plugs and losing power. I put in new plugs again and the same thing occurred.
I am at a total loss on what the issue is and would appreciate any guidance or tips.
