Riderrollin
I have a 1998 seadoo gtx that will start and dies immediately if all fuel lines are hooked up as if ready to head out on the water. But womt stay running. But if it is gravity feed from an auxiliary tank it will start and run wide open.
When I bought it rge engine was in pieces and missing top end jugs. I bought a used engine with 144ish compression from a 2000 gtx. I replaced the stator from orginal engine to the 2000 3ngine I installed in the ski.
Had a fairly good battery that when dead trying to get it started (turned over never fired) purchased a new battery turned over start and dies immediately as if it fires coughs and turns off.
It has had the oil injection system deleted from purchase date and I kept it that way. Using premix 50:1 per some reading that's what most had said to use in this situation.
But with gravity feeding carbs with fuel into the intake line on fuel pump it starts and runs its wide open rpm I'm assuming do to gravity feed and open lines not connected sucking air.
I put key on post it beeps twice starts and dies instantly if all fuel limes are hooked up ready to go to the lake.
It does have a couple old crap seadoo fuel lines left on it going from fuel sending unit to fuel on reserve fuel selection switch (was waiting on new bulk fuel line spools to deliver) I did disconnect them run fuel thru them and air and fuel again they don't seem to have any collapsing issues nor did any gunk form inside lines come out when I pulled and cleaned but am replacing anyways. Was attempting process of elimination.
I pulled the fuel sending unit to see if it screen was clogged or unit was cracked screen was surprising pretty Clean magnet on floathad some rusted shavings stuck to magnet but circuit board for fuel levels appears to be in good condition. I still need to reassemble the sending unit and ohm test it..... tester is on a job forgot to bring it home.
Pump is good Impeller sun fine when gravity feeding carbs. I have looked best I can with mirror and phone fuel tank has no cracks. Tonight I did find the oil injection unction wires that connect to top of oil tank have been cut back tucked away and wired together.... I assume to complete a circuit but this is the first 2 stroke I have worked with that is premixed vs injection.
I'm not new to pwc or jet boats this has me baffled. I have wrenched on many and aparently I'm overlooking something obvious and just getting irritated. Needing a new prospective on this one.
Tomorrow's plan is to pull battery and get a good charge. Test fuel sending unit ohms, and replace fuel lines. Check all clamps double tighten them to prevent air or fuel leak. Any other ideas or thoughts?
