where do i begin i have a 98 gsx ltd all was working fine decieded to take it out and had it running and it just shut down no alarms no overheat nothing... was unable to restart when i pulled the safty switch off and put it back on no beeps at all tested the dess accoridnig to the manual and it tested prefect, i also checked fuses those were ok also, i moved to the start/stop switch and did a resistance test accoriding to service manual, yellow/red to ground is supposed to read OFL (normally open) when i pressed the button its supposed to read 0ohms but it was reading OFL my question is could a bad start/stop switch cause the ski to shut down and not start back, or could the dess not reconize my key? or both?
thanks for any input
