97 xp please help
97gsx/98gsxl
ok my brother just picked up a 97 xp the kid he bought it from said that the ski was mint big mistake not taking it for a ride first
the ski fires right up on the trailer hooked to the hose runs like a champ the compression is 130 in the front cylinder and 125 in the rear when the ski goes in the water it does not start tried starting the ski then backing it into the water on the trailer and after a couple of minutes it died pulled it out and let it drain then fired right up does anyone know where to start. what would make the ski not run in the water its like a cat scared of the water
How much water was in it? If you only had it in the water for a couple minutes there should be little or no water in the hull.
