Working on a side project 97 xp with a whole host of problems. Randomly it will decide to start with the key in on the post but before that it would be completely unresponsive to any input.
Sometimes I could connect the battery and and get a moment where the gauges would respond but only beep once when the key even approaches the post.
Sometimes it actually works perfectly and consistently but then decides randomly to stop doing that and just be unresponsive...
Ever seen an MPEM do this ?
I've replaced a bunch of questionable wires and reterminated most of the AMP plugs at the mpem. Voltage and continuity checks all are good, and I mean the whole harness.
IT really seems like its the mpem more than anything else at this point. Weird thing is that I have two of them and they both do the same thing. I mean almost identical.
When connecting the battery the first time the gauges respond and sometimes I can get the 2 beems from pressing start 5 times. Sometimes it does nothing and just times out, Other times it would just beep ones each time the key is brought near the mpem.
Then after what seems like 10 minutes it just starts working for no apparent reason and stays consistent until the next time it acts up.
