What difference does it make what type of kit i use it still seals and honestly what guarantee do i have that the carb rebuikd would fix it
Firstly, as in life, there are NO GUARANTEES, only deduction by reasoning. But if you're asking that question, then your carbs have never been rebuilt under your ownership. Signs point to a fuel related problem and regardless, this NEEDS TO BE DONE especially after having water ingested into them as many times as you have had, especially not knowing which way the ski was flipped over.. It's like putting fix a flat in your tire without taking out the nail. You can flush out your entire fuel system, change all the fuel lines, use all the cleaner you want, and if those diaphragms and jets are clogged and your needles and seats (spring) is sticking, or gunked with mucky water, it'll be a waste of time.
Second, what difference does it make what kits you use? To me? None.. To anyone else? None. To you? It depends on what your time, energy and labor are worth. You will no doubt spend all your time rebuilding with cheap Chinese knockoff diaphragms, check valves, filters, gaskets, etc,... And then put it all back together, get a good ride or two out of it, then you'll be chasing another fuel gremlin and have to rip it all apart again because of a faulty check valve or a deteriorated filter clogging something up due to subpar materials.
I only say this bc IT HAPPENED TO ME.. I wanted to save $13.00 and since I just started working on skis, I wasn't too good with removing the carbs and linkage and return springs, so let's just say I spent a day or so out of my life just redoing something that I should've done from the start like all the guys on here told me to do.. Plus the entire week of downtime of no ski, as I was only able to work on it on weekends.
So just my experience, that's all. If you want those kits, you can find them on eBay or I think [MENTION=41828]Minnetonka4me[/MENTION] has them. Let us know what happens.
Good luck!
