Hi everyone im new to this site. I have read alot about the issue I am having with the ski. Its a 97 800 xp and was running great for 2 seasons and at the end of last year it started bogging at half throttle. I read forums and cleaned and installed new rave valves, changed out old gray lines along with fuel selector, filter, and pulled and cleaned carbs thinking it was a fuel/air problem. I also changed voltage regulator and checked all fuses. It will start and idle great and go to about half throttle then bog down. I talked to a guy and he suggested trying a spark tester to see if I was dropping spark and as soon as I get to where it bogs down the spark goes in and out almost like its hitting a rev limiter. I changed coil but problem still exists. I have read that MPEM could cause no spark but mine has spark until that point. Would that still be the issue im at a loss now as to what it could be. I have tried pulling harness off mpem and all connections look good. Vts gauge comes on when dess is put on and sometimes I get a beep and other times just a click but it always starts when gauge moves. Any help would be appreciated.
