97 speedster throttle lever loose
Slowmoe
Yeah my passenger side throttle lever is real loose; is there a way to tighten it or does it need to be replaced?
You can usually tighten it. Remove the trim panel. Then remove the screws holding it all in. Lift the assembly up and out of the hole. You will see a screw in the side of the lever base. you can tighten it.
