97 seadoo xp
What is your goal? Are you trying to remove the engine? You have to pull the pump off, then remove the c-clip from the rear shaft to remove the rear shaft then you can remove the front shaft from the PTO.
Yes I pulled the engine, I had it tore apart already and had to pull the crank case to flush it Out now time for a rebuild, thanks
