97 Seadoo xp 787
spiffy7
Ok- other than the grease fitting that is on the driveshaft when you open the
rear lid, WHERE else should it be lubed and how do you get to the area?
Thanks!!!
I recommend checking, and changing the pump oil every year. It's in the cone that you can see looking in the pump. You could lube the cables. Other than that... just keep it clean.
is their a recommended grease for the fittings synthetic or just normal since its being attended to more frequently with less hrs than an automobile.
