97 GTX. Normal engine noise?
AquaEye
1st Seadoo owned. 1997 GTX with 40.3 hours. Previous owner had ski stored for 3+ years with full tanks of oil & gas. Inspected before purchase & I insisted that we do not start for demonstration purpose's. Motor turned by hand easily( no spark plugs). Previous owner showed dealership maintenance records & all performed "by the book", (they also changed out the gray fuel line). Brought home, pulled pump & shaft for refurb, flushed/vacuumed out all fluids from tanks & lines & replaced with fresh, validated oil pump operation & clean out mud dobber nest. Compression test very good (see pics).
Before start up, fresh plugs & a "squirt" of syn oil in cylinders. Started up within 5 secs. Not knowing the sound of a running 787, I erred on the side of caution when that loud knocking noise occurred @ startup & immediately shut down. Installed air box, no quieter. Mechanic stethoscope was unable to pinpoint source. "Word on the street" is that rotary valve motors are inherently noisy. This noisy? Is this normal? Have short vid with good sound p/u but unable to post. Can use some help on that also.
Tags: None
Nope, that's not normal or good.
You have no output connection, correct? The shaft isn't connected and clanking?
Something isn't right.
Good luck!
Correct, no output shaft/pump.
I can only assume that this noise is not a normal occurrence(?). The dozen or so vids I saw the noise was present but not @ this particular level, but the events were always outside under flush. I'm in an small enclosed shop, just me & those freakin dirt dobbers.
Process of elimination> An old school trick I learned years ago, take a cutoff wheel, cut insulator to the shell, drill/punch holes/remove center electrode of spark plugs so as to relive some compression from the pistons but still labored. Impellor removal tool> socket>swivel & a strong high rpm drill motor. Have my buddy put down the beer & operate drill motor while I listen with mechanics stethoscope. Worked in the past, see if it reveal's any clues tomorrow. ( keep those modified plugs there a PIA to make), then the flush run if there is no solid determination.
There is something thou that sticking me in the side, the pump.
Previous owner stated that he lost ALL thrust before the sale. No mystery here, the liner was completely trashed. No thrust=compromised cooling capability & we both know what that can cause.
UPDATE: CoP's. Pulling head. With only 40.3 hrs & documented recommended oil used, those cylinder walls should be in pristine shape.
If not.....
Will provide pics.
Just an observation but from the video it looks like the cylinder cover has been removed in the past. Looked like the paint was half missing from the cylinder cover bolts. I wouldn’t have thought there would be a need to be in there in a 40 hour machine. I thought I could see the exhaust moving where it connects to the exhaust manifold but that’s probably just normal vibration. I’m sure you have checked all obvious bolts. I’m worried that the cylinders have been bored with oversized pistons and the rave guillotines are bouncing off the piston
I picked up on that also, the missing paint, unsettling to say the least. Rave valves were pulled, rather clean for 40 hrs,(too clean), no missing material. All three bellows/internals in good shape. Engine #s match to original title. Getting close to write this off for the summer for complete rebuild but more determinations are needed.
Been here before but only with Kawi's & Yami's. Rotary Rotax is a whole new territory.
I had one Yamaha 701. I should never have gotten rid of it. 9 years I had it and not a single issue, just drive
Nope, not a normal noise at all. Someone had that head off and absolutely no reason for that at 40 hours unless something was wrong.
I would pull the head first since it uses o-rings.
Became fortunate yesterday & witnessed the exact same year model GTX with 187 hrs @ the boat ramp.
Small discussion with the owner of my current dilemma, viewed the YT video I had posted & then started his GTX up....yeah, I'm in trouble.
Engine pull> tear down.
Hopefully, some of that clueless do-da luck I seem to have every now & then will spare me a cylinder bore & new pistons...or not.
CRAP! That & those freakin dirt dobber's.
10-4.
This is going to be a challenge. Got spoiled on pulling 2 stroke motors out of Yami's & Kawi's.
I see a chiropractor in my future....
Secured a robust engine hoist & a low shop stand. Next, the sling.
That should keep the chiropractor bills @ bay...or not.
The chiropractor bills are nothing, try lower back surgery. On second thought no, don't try it, it sucks use the hoist.
Just reading this for the first time. I don't know what you heard or didn't hear with the stethoscope but if the stethoscope doesn't pick up engine knocking (mechanical) then you don't have a mechanical issue. A lot of things could cause a knock or rattle that are not internal mechanical looseness. You're compression is great. Very difficult to diagnose when you don't have hands on but me... I'd ride it and see what it does in the water. I'm not pulling an engin without good reason. Check your engine mounts and all that stuff too. Just some ideas. Good Luck !
When you revved it is seamed sluggish. Good luck again. LOL
The stethoscope did pick up the loud knock very clearly. Very confident it is internal but as to "drill down" & isolate the particular area, the confined space(s) & length of probe denied me that & the intensity resonated throughout the entire casting. Would have used my borescope & supplied pics of cylinder walls/piston tops but my deadbeat brother in law had it down a cylinder & hit start. No mystery what happen there. (he's in no better shape bty)
No revs, just idle or just off, with that loud noise, I choose not to "roll the dice". Been doing 2 stroke since the early 80's. "Alot" of reasons determined & dismissed by process of elimination. This is my 1st rotary valve. Teardown/rebuild during "off season". Taking my time & will proceed methodically.
The hyd cylinder for the engine hoist is @ the shop receiving new seals. The engine hoist was bought @ a govt auction decades ago @ the Red River Army Depot & traded up with previous owner. Has the "old" rope seals & the hyd shop owner estimates a 8 to 10 ton hoist capability. (this is overkill, I know)The legs themselves extend to 101" but still have room in the shop to pull away & move trailer out. This lift is a beast.
Got the low profile shop stand with adj bunk widths. Next, the lift slings & this is where I have no clue on what type to purchase. Never used them, never had to.
So that being said. Can someone whose "been there, done that" recommend a robust, reputable & proven sling? The applications will be to a 97 GTX, 2012 VXR & few other 3 seaters that my friends have so as to replace bunks/trailer repair etc.. (SD, Yami & Kawi).
Never used a sling and I shuffle skis on and off trailers and stands all the time. If you spray the bunks of the trailer and stands with silicone spray one person can transfer a 2-stroke 3-seater.
Make sure you tie it down to the stand so it doesn’t slide off, land in the street then call for your wife to come out and she just laughs at you. Yes first hand experience.
Been doing the lifting, sliding transfer thing for far too long. Time for the upgrade plus most of my compatriots have the fancy 4 stroke couches weighing upwards of 850/950 lbs, my VXR is probably the lightest (732lbs) of the 4 strokes in our little band of misfits.
I too have seen a brand new, first maiden voyage 3 seater, s-c 4 stroke Kawi on a landing ramp just feet shy of the water cuz the "new owner" just HAD too use that silicone so as to make launch "turn key" easy" & w/o complication... SMACK! Yeah, cherry got popped in short order.
All fun & games until someone loses an eye BUT the question still remains,
"Can someone whose "been there, done that" recommend a robust, reputable & proven sling?"
You might have better luck in the 4-stroke section as they have to move the heavy skis more.
