97 GTX low oil light
yukey
Just rebuilt carbs and replaced old grey fuel lines. Tested in water and ran fine.... very fast and smooth for about 20 minutes. Quick note.. I have 2 exact same model & year GTX's so i pulled the sensor from the bad oil tank and replaced with the good one. Again, it ran fine for about 20 minutes and once again the low level oil light came on. The tank is about 3/4 full. Any suggestions???
Oil Pump?
Since you get the same results with two different sensors you could either have a blockage, or a bad oil pump. Also there is a filter that could need changing.
Disconnect the lower line from the filter, clamp off the line so you don't get air into the line, and see if you are getting oil flow.
Sorry I misunderstood the question the above is not the problem. You will need to check the wiring and wiring connector, there is a schematic for your ski in the manual which you can download from the Premium Member section.
Lou
