xMambler24x
I recently acquired 2 97 skis and the GSX with the 787 I can’t seem to get fuel to the carbs. I know all the lines need replacing, but I’ve bypassed the fuel system with a new line and a primer bulb plugged directly into the carb on one end and the fuel tank on the other and it cranks up fine, but only runs if I’m priming the bulb. When I connect everything back to the fuel selector switch, and fuel filter inlet and out the thing won’t fire up. What else can it be if I’ve replaced both fuel lines going from the selector to the filter, and from the filter to the carbs.... the two other lines from the fuel selector to the tank are both old, as well as the breather line. Any ideas??
