Dear Seadoo enthusiasts,
I bought a used challenger about 2 months ago and am working on a view issues since then to get it to run properly. I am not very familiar with seadoo technology but have some hands on background dealing with 2-stroke engines.
Currently I am working on an issue with the rectifier/regulator (RR). I measured the voltage at about 5000rpm and it was rising over 15V and I read on the forum that that indicates that the RR is bad and needs to be replaced. Therefore I bought an used one (was told it had been tested) and installed it yesterday.
The first time I started the boat it showed the same behavior as with the old RR. First I thought that I received a faulty part or that something blew it right away. But when I let the engine running a little longer at 5000rpm and the voltage dropped to 14.2V and the RR seemed to be working properly. The thing is that from time to time the voltage increases slowly up to 16V as if the RR is defect but then suddenly drops to 14,2V again as though the RR is working fine.
My question is now what could explain this behavior and how I can analyze the cause of this and fix it. Is it correct to assume that the RR is intact? Wouldn't the voltage be over 15V permanently if I run on constant 5000rpm when the RR would be defect?
Could it be the stator? I measured the yellow cables against ground and they were all open. Is there any other measurements I can do to verify that the stator is intact? And again, does it make sense that the problems comes and goes when the stator would be faulty?
I thought that it might be bad ground between battery and motor? The only connection between battery and motor I could find goes to the starter. The cable and connectors look good. Could the behavior be explained with a bad ground connection?
The whole thing puzzles me a lot as it looks like the RR is working some times and sometimes not. Any help or suggestions are very much appreciated.
Thanks and kind regards
seeedooo
seeedooo
