nam_sprayin
Ive got a 97 challenger 1800. The driver side motor will run good for a few minutes then shut off, when trying to restart motor hard to turn over due to overheating. At first i thought it was a not getting fuel, thought maybe a clogged fuel selector valve. I turned the fuel selector halfway between on and off and it ran for about twenty minutes the shut off again and wouldn't start back up. I opened up motor found the rings shot. Rebuild top end completely and tested it again. Motor ran strong for a 5 to 10 minutes and shut off again like before. The motor was very hot. Pulled the plugs they looked good, didnt look like it was running rich or lean. Pulled oil pump to see if it was working. Does anyone know of a good way to test the oil pump? I pulled the feeder lines to cylinders off both oil pumps and bumped over motors they were working the same so I think its not an oil pump problem. If anyone has any info or thoughts on possible problems, that would be very helpful. Thanks
