IANONTOP
Trying to see if i can get a little technical help.
From IDLE TO WOT. The ski gets up quick cruises at 20 and slowly climbs then for 4 secs up to 52mph. In short ski has a dead spot transitioning form low speed circuit to high speed circuit. Once im in the high speed circuit, the ski responds very well. If i feather the throttle it will take off from a dead stop. If i sit there a second or two it will do what i stated earlier.
The carbs are fairly new and rebuilt with mikuni kits and new mikuni N/S on both carbs. Completely cleaned all orfice holes are free and clear. The fuel line is direct from res to carb with inline filter. (No selector or water separator) also stock f/a’s. Have tried all amounts of pop off pressure from 20, 28, 34, 40, 50. Only difference is that higher pop offs lean out ski as expected and the lower it starts four stroking (too much gas) Also low speed adjuster makes no difference neither should it. No longer has affect on fuel delivery as of this point in transition. Im tired of messing with it and im at a wall. TIA
