furrywolf316
The xp will start normally and Idle normally but after launch it feels like it drops a cylinder(engine breaks up). I can turn off the engine and refire it and the problem goes away until I take off again. It will run 10-30 seconds before it breaks up but stopping and starting the engine will clear it. After this has happend a few times it will stop acting up and run normally. If you hit the trim button the engine will momentarily pick back up but only for a second. The ski was put up with this problem and sat for 2 seasons unused. I drained the old gas, went through the carbs and replaced the 3 filters. Compression was good on both cylinders too. If anyone has any clue on what is causing this I'd love some help.
Thanks
Thanks
