i got the adjustment for the low spped screw which is 1 1/4 turns. but somebody removed the cap on the high speed adjuster screw and i cant find any info on what to set it to. any help would be appreciated
It's not a big deal if the cap is gone. I pull them off most of my carbs. The reason they are there is so people can't run the carb so lean that it melts the engine. But with most seadoo's... they jet the carbs for a closed high needle, so you can only go richer.
