steveobc22
My 96 speedster is boging down at 4k rpm acts like it is starving for fuel. If i pull the port engine back the starboard will stop bogging and run full. I checked the voltage yesterday at the battery when running at 5k rpm on the port engine the voltage was 12.87 and when i ran the starboard at 5k it was 13.2. I checked the voltage one engine at atime,not both running together. Should this make a difference, do i need to run both at the same timee to check the rectifier? Also i checked the fuses in the mpem, all were good but i assume i reset the computer and the boat seems to have fixed itself, could it be a limp mode. I'll put it in the water and see if it worked today. thanks dr.honda
