96 Sea Doo Sportster Help
Dav3502
Hi,
I screwed up and ran water through the flush system prior to starting the engine. I have removed the plugs and blew out as much water as I could. I removed the spark plugs and turned the engine over. The pistons are moving up and down as they should in the engine. When I go to put the spark plugs back in, the engine does not even turn over. Is it possible the exhaust system is backed up with water. If so, how do I purge the water? If not any other suggestions. I was able to blow pressurized air into the engine and that blew alot of the water out. I then sprayed some wd40 down into each cylinder. Hopefully this was the right thing to do. Any help or suggestions?? Thanks
