kyleasharp
ok ski has been stored i had to put a starter in it the old one worked but not every time. new battery, new spark plugs, new gas new oil.
787 rotax
the ski starts every time 2 seconds of choke while cranking cold, some throttle, and it will idle at 1500 in the water, and about 2000 on the trailer.
I took it out the other day and it smoked black which i figured to be normal form being stored. however it just wont revv out. it will run at like 3500 but thats it. spitting some but not much. the black smoke is gone and now blue like it should but there is still too much. the plugs oil fowled. its like there is pressure building in the exaust but its not. i have troubleshooted this for a couple days now. i am trying to rule out carb problems because it starts, idles, and i dont have to use choke during wot. i can hold the throttle down and it just like bogs. it is intermittent though. 1 time i got it to tac up to 6000, then it just died off to 3500 again. it will sometimes take off from idle but it like builds pressure or its not timed or advancing the timing. im about to pull my hair out on this. any thoughts? any questions?
787 rotax
