96 gts only runs with rev limiter unplugged
Dj seadoo
My 1996 gts 580 will run and idle perfectly with the rev limiter unplugged, but if it’s plugged in will only run for a second then shut off and will only turn back on by removing the 5A fuse and putting it back. i don’t mind not having a rev limiter but then i have no kill switch
Hi,
When you write "rev limiter" you are refferring to a switch, correct?
If so, that sounds like dirty contacts on a switch, making it work randomly. To confirm that you can replace the switch.
Good luck!
