Mickirig1
Take pictures as you take it apart. I bought a cheap litter box to disassemble the carb inside it. Any screws or such ends up in the box and not on the floor. Keep the old parts seperate from the new. Get the pressure tester from OSD. You need a bike pump to get air pressure to test pop off and other parts of fuel system. See his instruction on the tool to make, to install check valve rubber pieces. It will save your sanity! Read the sticky at top about carb adjustment. A great source of info. See the posting about tricks to rebuilding carbs I started. It will be helpful. You can do it! Just take your time and ask questions. This site no one will be mean or talk down to you. We are here to help our fellow PWC owners!
