GWNSeaDooOwner
Hi.
I purchased a 96 Challenger last fall and have been having problems with acceleration. Originally last fall, I took the boat to a dealer here, and they said that there was too much gap between the impeller and wear ring. Both were replaced. I never got the boat back in the water until this summer, and the boat does the same thing. On take off, it takes anywhere from 15 seconds to never to get up to speed. The RPM roars but the boat only achieves about 10MPH. It seems that if there is weight in the front of the boat it will plane after some period of time and reach about 45MPH. I called the dealer back, and they noted that when it was winterized that they suspected a cracked block. After speaking to another dealer, they told me if there was a crack in the block, the engine would have seized. Now I'm lost, and don't want to dump more money into this unless I can be sure it will help. I did read about Smart Tabs by Nauticus, and wonder if they may help. Any info would be appreciated. Thanks!!
