del_scotland
Hi, I just bought a Sportster with twin engines (See pics).
After 15 mins; on the water the drivers side engine cut out, then started and cut out a few mins; later and would not restart in the water. A few days later it restarted on the trailer thou.
I checked passenger side engine compression and both cylinders are sitting at 138psi.
Drivers side engine shows rear cylinder at 60psi and front cylinder at 115psi.
I removed the head on the drivers side to check the condition of the piston tops and cylinders and not scored or lipped. However, I see the front cylinder piston has markings on it 010-817-05 & 0.50, the rear cylinder piston has no numbers/ just the exhaust side arrow. It appears to me that there has been a 0.5mm oversized piston placed within the front cylinder and the original piston cylinder left in the rear?
I understand from the both cylinder psi readings of the drivers side engine (60 & 115psi) that both piston rings will probably need replaced with a top end gasket set at least.
I have included a lot of pics for further info.
Can anyone answer the following...
Going by the top piston markings, is one piston original size and one 0.5mm larger?
Is it ok to run an engine with these different looking size pistons?
When I buy new piston rings will i just buy the standard 84mm rings for both the existing pistons?
Any other help at this time would be much appreciated
Thanks for your time and help!
