95XP loose coil PLEASE HELP!
wrong3000
hey guys i am really stuck on this problem!
any ideas at all would be greatly appreciated!
the craft cut out in mid fight, now theres no spark, so i tested the trigger coil(black/red -black) MAG wires and the ohms where changing from 4ohms to 60ohm as the engine was turned by hand. So i removed the MAG cover and found the battery charging coil had come loose, but the trigger coil was fine and tests out fine now.
would this cause no spark??????
please any advice you have would be greatly appreciated!
thanks
