AKnarrowback
Hi guys.
I'm getting around to rebuilding the 98 xp Ltd I killed last year. This is the second bore over stock and I want to make sure the clearance for the valves is safe.
Right now I do not have any contact of the pistons or rings with the valve assemblies stock and bolted in place. Can you guys give me some insight into how much material should be removed from the valve, any way to really measure it, pictures of cut - vs - uncut valve face. It seems like a tough surface to measure and be sure of how much you have moved things back.
Thanks!
Thanks!
