I just had my 951 DI rebuilt. He replaced the counterbalance and crank as the gears on both were destroyed. The crank had the timing dot on it but the counterbalance (WSM i believe) had 3 different marks on it marked I,II and III. They were all 120 degrees away from eachother. He ended up using the III mark which gave this counterbalance configuration as seen in this video at 2:58.
Is this correct? Ive read that the weights should be facing opposite directions but this video shows otherwise.
