95 XP water in Hull
chasenfish16
I have a 95 XP and GTX after riding about three hours I get aprox. a quart of water in the hull. I have looked at it on the hose and strapped to the trailer running in the water and cannot find the source. I have checked the exhaust, lines and replaced the siphon tubes also it does not look like the thru hull seal is leaking because when I add grease to the zerk, the grease that comes out does not look like it has water in it. I checked the VTS assy. and all thru hull fittings also. Is this common on older ski's or should I keep looking.
your good dude idealy you dont want any water but for the most part all skis get water in the hall some way or another. the water is probly coming in throught the rubber seals under your seat or hood nothing to wory about with a quart if youve checked all the lines and u can find leaks on the trailers then im almost positive it would be coming in through the seals. another possible place to look would be the intake for the fresh air into the hall prity easy for the water to get in through there .
