I picked up a 95 XP project a few weeks ago and I've been collecting parts in hopes of getting it running for the next season. Today, I put in the new battery I picked up from Amazon ( link ) and it did not end well. I put the battery in after wire brushing the terminals to make sure they're fairly clean I then screwed them down tightly and put in the key to try to start it. Problem number one is that the starter can not spin the motor very fast when the plugs are in but it has no issues when the plugs are out, and problem two is that after cranking the starter about 5 times total there was slight smoke coming from the ground on the battery and I come to find out it has melted the metal terminal on my brand new battery. Why is this happening all help is appreciated.
I have checked to see if the ground is loose and it is not. I did some research and I'm seeing it can possibly be a bad ground wire. I am unsure, but if it is that where can I buy a brand new one and not a used piece of junk on ebay.
I also have looked through the motor. It spins completely freely and has good compression. I'm unsure as to why the starter can not spin it with the plugs in. Possibly a bad starter.
