Tenacious D
I have the manual and see that it calls for a 1.2 needle (which I now have, but is suspected of leaking) for my BN-38I dual-carbs...but I've heard others advise to use a larger size as a replacement, particularly, a 2.5 needle / seat.
Here are my questions on that advice, and one other general question about my carbs:
1. Is it more advisable to use the larger needle, though not OEM, and if so, what would the benefit / result be from doing so, if anything? Or, is it it simply best to stick with the 1.2 needle?
2. If I do use the 2.5 needle, what type of spring would be required to ensure for the proper pop-off, if even possible to do?
3. What is the difference between a "BN-38I" carb and that which the Mikuni guide shows as being simply a "BN-38" (without the "I"), if anything? Is there a real difference, insofar as replacement parts / kits are concerned, or is it simply a difference in nomenclature (meaning, Mikuni's listing it as a "BN -38" is intended to encompass all models of that carb, including the "BN-38I")?
Thanks, in advance, for any advice or suggestions.
