eavega
Hi all
I am trying to bring a 95 SPX back to life. First step was to replace the fuel lines and rebuild the carburetors. Therein my problem lies. I have disassembled the carburetors, and found that they have 1.5 needle valves. I've read a bunch on the interweb that recommends that these skis have the 2.0 needle valves. I have no history of how this ski ran when it had the 1.5 needle valves. I'm also fairly sure I damaged the seat trying to get it out of the carb in the first place (took a lot of grabbing, twisting, and pulling to get it to break free). I WAS trying to be careful to not push the pliers all the way down to where the needle would actually contact the seat, but I am not sure I was successful. There are no obvious scratches down at the bottom though.
So, my question: Should I
1. rebuild the carburetor, use the needle/seat that was in there and hope it was the right one and I didn't damage it getting it out in the first place.
2. Rebuild the carburetor, replace the needle/seat with the same sized 1.5 I found in there.
3. Rebuild the carburetor, replace the needle/seat with the 2.0 that the online information seems to point to being what is supposed to be in there.
Do the needle size even matter? Is it more of a case of the right pop-off pressure for a given needle/seat size for the engine? I'm not totally clear on the importance of the needle/seat size. I've only previously worked on motorcycle and outboard carburetors which don't use springs and popoff pressures. Those carburetor needles rely on floats to get the needles to open and close at the proper time.
I'm at the point now that I am ready to order the rebuild kits and needles if necessary, so any guidance or suggestions would be appreciated.
Thanks in advance.
Eric
Thanks in advance.
Eric
