twentythreemx
keep reading for long version!! or heres a short one. what can cause me to fill up with water, just about covering the battery (or even higher?). ran perfect for about an hour. recently changed fuel lines and stuff. now it shut off and was full of water.
long version!!!
Ok, so maybe you've seen my previous 2 threads about problems. Well, I got that all straigtened out. I bypassed stock fuel filter and put one from autozone on, and replaced all the grey lines with 1/4" fuel line from autozone. new plugs, cleand the filters in the carbs (and cleaned the carbs a little bit, didnt take them all the way apart), set high speed/low speed back to stock settings (just to make sure)
it ran GREAT for an hour, best ever since I bought it. i was so excited!
then.. it died. it sounded like it did before the problems, tons of gas, low revs, barley moving, just.."Blaaah"
then it shut off. noticed a ton of smoke come up from under the hood i was like wtf that cant be good!! it went away though thought osmething got wet maybe.. didnt look under seat yet. started but sounded TERRIBLE
turns out, TONS OF WATER IN AROUND THE MOTOR. was past the battery. started to tow it in towards the beach. by the time i got to teh becah it was sooo full of water I really thought that it might sink, it was scary.
so.. pulled it up onto the beach and drained all the water from the plug (it literally took like 7 min to drain it all). towed it back in, tried startin ga few times (just to maybe pump some water out? idk).. it started a little but i sht it off til i could get home and take the plugs out and make sure no water was in it
so i got it home pulled plugs out and turned it over a lot.. nothin comin out so i think im good there. it fired up and seemed to run fine out of water so i think it must have just been the water screwing it up?
anyways.. i checked for cracks and stuff,dont see anything obvious.
i figure 2 things happening, either its getting water in somewhere it shoudlnt, or its not sucking water out the way it should
dont have a clue where to start.. any ideas? ran PERFECT for an HOUR then just died and filled with water
thanks for everyones help previously, as it gave me enough advice/motivation/confidence to do the fuel line job and it worked great, but now this.
any ideas would be aprpcieated! thanks
long version!!!
