In a previous post I was advised to check my fuel system (one engine would not rev above 3000 rpm) so I pull the carbs and find the rear carb fuel chamber where the needle valve is, dry and also the fuel return line was dry. I get a rebuild kit and when putting it back together I try blowing through the nipple were the return fuel line connects and can't get air to go in either direction, I tried a piece of weed eater line then a piec of wire but still no go. what Is the deal ? shouldn't air move freely here ? see pic. I did have this cover completly off tha carb when I tried this, the only thing different with the pic is the fuel line connecting the two carbs is still connected.
