95 sp no spark issue
Blakeb
Hey everyone, first post here. I'm having some issues with my 95 sp 580. Had it out on the lake all day and it was running fine, then I killed it and it would not restart. Found no spark was the issue. Ran the ohm tests on the mpem and found several readings out of spec. Ordered and installed a new mpem and still no spark. Could someone please give me some advice as to what else to check? First jetski I've owned and only had it a month so I've got alot to learn. Thanks in advance
Also to add, I have never heard the ski make any beeps in the time I've owned it. Now after installing the new mpem, when I put the lanyard on I get 2 beeps and when I pull it off I get one short beef one long beep and another short beep. I'm not sure if that has anything to do with the issue.
I will add yet again, I am getting between 5 and 6 volts to the coil via the black wire with red strip while cranking.
I wish I could help but I'm not versed well enough with electrical. I would recommend finding a manual. That at the very least would be able to tell you what the beeps mean.
How much was the MPEM and where did you get it? I had a no spark a couple of times on my 96 SPI. I just released the key and reinstalled at it started right up. I can say this.... I rebuilt my carb with aftermarket kit (my first ski as well) and I had trouble starting right away. The ski fired right up before I rebuilt the carb. After a few problems I found the valves in the fuel pump being the issue so I ordered a new OEM kit which I will install today. Good Luck !!
Correct me if I’m wrong but you shouldn’t have any beeps with a 95 when you place the key. That sounds like a DESS system that was implemented until 1996. I recently had the somewhat of the same problem. Chased wires and metered everything. Come to find out it was a short in my safety switch. Replaced it with one from a boat and now it runs great
I agree, I also have a 95 sp and you shouldn't get beeps when plugging your lanyard in. It sounds like you got the wrong mpem as the beeping started with the later models
