I have a 95 sp that seems to run out of fuel when you throttle it. i have replaced the fuel lines first day i bought it. i found the water fuel separator o ring in the front storage bin so i thought it was leaking air into it and causing fuel shortage. well i was at the lake when i found that so i sealed it with a fat bead of superglue around the cap and it seemed to work at least for a while it acted up again. if you pull the choke out a little it would seem to run ok but act up as soon as you let off the choke. i looked at the water fuel bowl and it is full of fuel, clean filter in it. it will idle good in or out of water but give it gas it dies. the plugs look good not wet or black good brown. i took the fuel line off at the carb and it has a free flow of fuel coming out. anyone have any idea where to look next? oh and i have a new water fuel separator on order. thanks in advance
