The black wire and black with yellow on the DESS post connect to the center and ring on the post. When you put any DESS key on the post it connects those two wires just like a spring loaded switch. The white/grey wire is the code wire that wouldn't be used in this setup. You have to cut a larger hole in the deck for a DESS post so it would require thin washers that won't rust to use the original spring loaded style again.
