95 HX Fuel line venting help
GCAZ
I need help figuring out the fuel line or gas tank venting routing. I picked this ski up as a project and one of the first tasks was to replace old fuel lines. I have run all the new lines and came up short on one connection at the check valve. What I currently have is a line coming from the top of the tank into a Y splitter. one side off the Y goes to the check valve that comes out the top of the hull in front of the seat behind gas filler neck. The other side of they Y goes to a connection/grommet that exits the hull just under the front of the seat. Now the part I cant figure out is where the pressure relief valve is supposed to be routed to. in diagrams it looks as though the check and relief valves are routed off the same line and just T'd but it doesnt show the connection that leads to under the front of the seat. Hopefully my question makes sense.IMG_1849[1].JPGIMG_1851[1].JPGIMG_1850[1].JPG
