cleaned the carbs twice, replaced diaphrams. replaced main fuel line and put a inline filter right before the carbs. also replaced the line inbetween the two carbs. new spark plugs. I set the adjustment screws same as they were before (carbs had never been touched). it will run but its hard to start. acts like its flooded, have to crank for a long time with the throttle open and it will eventually run. even does it when warm. pretty much anytime you shut it off its a battle to restart. this is a seadoo out of the pair I just bought. the compression is on the low side, 120 psi on both, but even at least. what should I try? turn the idle jets closed some?
