andy.262
Just got a '94 XP for a decent price, but it has some issues. Engine will start right up no problem and idle for about a second or two. During that second or two if you even think about touching the throttle it will instantly die, won't even try to rev up.
Previous owner said he has done the following work:
- new pistons and rings (checked compression, 150psi both holes)
- carb rebuild
- timed rotary valve
- switched to premix and removed oil pump
- installed new in-line fuel filter
I plan on doing the following:
- rebuild carbs again with "back to OEM" kit from OSD
- replace fuel selector
- replace any remaining grey fuel lines (there are one or two left in there)
- remove in-line fuel filter (because there's not supposed to be one there, right?)
- re-install oil pump (I have a seperate forum thread open for this particular task)
Anything else I should be checking/trying?
I did notice that it does not have that water separator cylinder like my other 2 skis have, but I'm assuming it is supposed to have one?
- carb rebuild
