Background:  Purchased 1994 GTX with hole in Mag Cylinder.  Diagnosed as problems from old gray fuel lines.  Replaced all fuel lines (did not replace selector switch as it was clean but cleaned it anyway).  Split case to clean out aluminum.  Rebuilt top end (now has 150 psi in each cylinder).  Finally got it all back together and it started right up but the oil lines which I also replaced (as well as the oil filter) are not purging.  There is about 1cm or "bubble" remaining in the line right before the injector nozzle.  I replaced the small hoses and "blew" out the nozzles.  I am running 40:1 premix as a precaution.  Any ideas as to why the oil lines will not purge?
My cleaned carburators are also running very rich. I will ask about this in a separate post but just wanted to mention it here.
