I put a freshly rebuild 720 engine with 150 psi in both cylinders and a 720 electrical box in a 93 xp that origionally had a 650 in it. I have a Factory Pipe Exhaust on it and an Ultrac Head with an Ultrac water box. (Ultrac is a brand name I think they don't exsist anymore) It has the electronicly controlled water injection that the pipe came with hooked up as well. The problem is I am not sure if I have the cooling system correct. The cylinders seem a little too hot when you touch them while it is idleing. You can still hold you hand on them and the head but I am afraid of taking it out and it over heat. I ran the water lines according to the factory pipe drawing but not a 100% on it.
Also any suggestions on jetting? I have it at about what factory pipe suggested but not sure it is correct.
Any advice would be appreciated
I can put up pictures of the ski and engine and hose routing if you would like
