Tjdavis3107
Title basically says it.
This past weekend, I obtained two 93 seadoo SP's from an old friend who claims they ran two seasons ago. I took them off his hands, in hoping that they would be a good beginner ski for my nephews.
First thing I did was purchase new batteries, and attempt compressions tests.
Ski 1: Cranked just fine, but will not turn over. The compression test was 145 on both cylinders.
Ski 2: Would not crank via ignition switch, but did with bypassing the starter solenoid, would not turn over though. The compression test was about 148 both cylinders. This ski has a milky water sludge in the hull, just high enough to hit the battery base plate.
Question 1, what suggestions/troubleshooting advice can anyone offer to get these running. Also, any ideas on what is either causing the water/sludge in ski 2, and any ideas to get it out?
Thanks in advance!
Thanks in advance!
