jack88
What is required to install a 92 xp manual vts cable set up on an x4 hull. Would I need to cut a hole for the knob? Can I convert it to a lever?
I was originally looking for a 96 hx system with the knob at the back, but I found a 92 set up locally. I think I like the 92 set up better since it can be adjusted on the fly, where as with the hx system you need to get off to adjust it, or stop and reach back.
I just need confirmation on where I would put the knob, or if it's easy enough to go with a lever, and if there are any additional parts that I need to buy to retro fit it.
