ok so its still not running 100%. How many fuel filters do these things have? and if there are some in the carb, will i need a carb kit if i have to clean them to be able to put it back together? it just sounds like its not getting enough fuel. out of the water, i fire it up, grab the throttle and open it all the way and it will tac out and hit the rev limiter (mind you, one for a second or two) and it sounds fine. as soon as its in the water (under a load) it will only go so fast, like 10 to 15 mph. im going take off the flame arrestor assembly and fire it, to see if both carbs are getting fuel and to make sure they are opening all the way. and im going to check all the fuel lines. Anyone want to give any input?
