mattrourke
I'm sorry if this has been covered but I've been searching and haven't found a write-up for doing the EFI Leakdown test. This is completely new to me so I'm not at all sure how to set this up. I found info for the carbuerated engines but not for the RFI.
My understanding is I need to block off the exhaust and the intake somehow and provide air pressure to the pulse line and then install a gauge somewhere to monitor the leak down.
First off... Which is the pulse line? I believe I can just hose clamp a valve from an inner tube onto there and use a bike pump to create 10psi... Where do I then install the gauge to monitor it or can I just watch the bike pump gauge?
Second... The engine is still in the machine and we are trying to find out where I'm losing power so I would like to keep the engine mostly installed until the problem is diagnosed... Can I unbolt the exhaust and the intake and create a rubber block off plate from an inner tube or something and bolt them back up to create a rubber barrier? Or do I need to create an aluminum or steel solid plate?
Is there something else I'm missing completely?
