Good day, I have a 1996 XP with a 787 engine. It starts fine on the hose and will rev up easily but as soon as it's in the water it will start harder and won't rev up at all will just sit and idle, as soon as I try to rev it wants to die. When I bought it it was doing it found sleeves where bad so had them rebored to 1mm over and did the top end but is still the same afterwards. Compression shows 90psi but is a cheap gauge so not even sure if it works. Checked rotary timing, replaced spark plugs, redone fuel system, converted it to premix, cleaned the carbs, squish is 1.4mm. Don't know what can be the cause, don't want to rebuild the carbs if not necessary because I live in South Africa and Makuni kits are hard and expensive to get. Any help will be highly appreciated. Attached a zip file with a video if it helps.
