My boat has the twin 787s. One motor starts/runs excellent. Other does not.
Heres what happens;
I can get the motor to start on the trailer but I almost always have to be using the choke. Even when the motor is warm. Once it runs it sometimes stays running but usually sputters and stalls. If I put it in forward and tthrottle up I can keep it running.
On the water its hard to start. When I do get it running, if I can throttle up past 4000 rpms it will stay running and run great.
Ive taken the carbs off a couple times now. Im not sure what to look for next. When I took them apart the gaskets and filters look good. All fuel passageways seem clear. I dont have a popoff tester so I cant check pressure inside.
Good compression, new plugs, Cut back plug wire ends, raves just cleaned.
Any ideas???
Thanks
Heres what happens;
Any ideas???
Thanks
