I recently bought a 1998 seadoo challenger 1800 from a private seller. He swore up and down there were absolutely no problems.. when I went to pick it up, he started both engines for about 10 seconds saying he didn’t like them on out of water.. he refused to take it out the lake but promised if I had any problems i could take it back for a refund. We shook on it, I took the boat home and tested it on the lake next day.. both engines wouldn’t start. I used a booster and they started but the port side engine kept shutting down at idle... I also heard a back fire sound coming from that engine... I took it to get checked out, and was told the rear cylinder was reading 0psi and the other was 140psi. It needs either a top or full rebuild.
Does anyone have any suggestions on what could be the cause and possible solutions(what could cause a cylinder to fail)? Also do I need to work on the carbs at all?
Where can I get a step by step guide to remove the engine?
Thanks in advance
Thanks in advance
