IDoSeaDoo
When I got this jet ski, it ran great. No hesitation, no hard starting. The thing just ran, and ran well! Put a huge grin on my face every time. Then, the needle bearings at the wrist pin let go and killed the piston, rotary valve and brass gear. After some tears, I got another rotary valve, RV cover, brass gear and pistons, but ever after, I was battling this damn problem. The main thing that changed was the RV cover.
I went out and measured it last night, I was able to stick a .33mm feeler in there and BARELY get a .4mm in there, but that was REALLY tight. So I popped it off and put some thin solder in there. It squished to about .36mm That is about .05mm out of spec. Is that really all it takes to ruin the performance of these boats? I don't have any other RV covers that are any good, so I'll be shaving down the ears on the existing one with valve grinding compound against the block till it's back within spec. Looks like I'm also going to have to heli-coil at least one RV bolt hole on the block. yippie... I love manually drilling out aluminum with a T-handle.
